EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Change order of pages in EAGLE schematic
4 REPLIES 4
igcst
1390 Views, 4 Replies
Hello
Is there a way to change the order of pages in an EAGLE multi-page schematic ?
a) Manually
b) Using some ULP ?
4 REPLIES 4
jorge_garcia
in reply to: igcst
Hi @igcst ,
I hope you're doing well. You can manually rearrange the sheets, just drag and drop the sheets in the sheets dialog.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
igcst
in reply to: jorge_garcia
I have difficulties with that approach - somehow it is not working for me.
Is it possible to do the rearrangement by some commands, by ULP script or by some other way ?
Is it possible to rename a page ?
jorge_garcia
in reply to: igcst
Hi @igcst ,
Could you provide some screenshots? It should work the GUI way without issue. However there is a command line way to rearrange them.
EDIT .s2 .s5 moves sheet 2 before sheet 5 and loads sheet 2.
Sheet numbers are pure numbers so they can't be renamed. If you see names with the sheet then that is related to modules and you would have to rename the module to get the sheet name to change.
Best Regards,
Jorge Garcia
I wish to make Links on the first page of Schematic (of many pages): i wish to write on page 1 "sheet2".  When "sheet2" is clicked, Fusion will open Sheet 2.  Any help how this can be implemented? Thanks.
Tags (1)
