EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Change Layer command for Group
4 REPLIES 4
cdenneyB9ZMH
16810 Views, 4 Replies
I just discovered a cool command for changing the layer of a single object. Just type "change layer" in the command bar and you can change the individual object to the new layer you've specified. Cool!
But really, I have a whole group of objects that I'd like to change the layer of. Is this possible?
-Chris
4 REPLIES 4
Hi Chris,
Thanks for your participation on the EAGLE forums. Define your group, on the command line type "CHANGE Layer", select the layer you wish to use.
Now do a RIGHT click anywhere within the defined group, and select the option  "Change:Group".
I hope this helps.
Ed
Please 'accept as solution' if my reply resolves your issue.
Edwin Robledo
Tech Marketing Manager
Thanks Edwin. I will give that a shot next time!
marecekmach
in reply to: edwin.robledo
Worked for me! Thanks
C.Nicks
in reply to: marecekmach
Also note a shortcut to the right-click "change:group" is to hold CTRL/CMD and right click.
Best Regards,
Cameron
Eagle Library Resources
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
