Change Layer command for Group
cdenneyB9ZMH
cdenneyB9ZMH
I just discovered a cool command for changing the layer of a single object. Just type "change layer" in the command bar and you can change the individual object to the new layer you've specified. Cool!
But really, I have a whole group of objects that I'd like to change the layer of. Is this possible?
-Chris
edwin.robledo
Hi Chris,
Thanks for your participation on the EAGLE forums. Define your group, on the command line type "CHANGE Layer", select the layer you wish to use.
Now do a RIGHT click anywhere within the defined group, and select the option  "Change:Group".
I hope this helps.
Ed
Please 'accept as solution' if my reply resolves your issue.
Edwin Robledo
Tech Marketing Manager
cdenneyB9ZMH
Thanks Edwin. I will give that a shot next time!
marecekmach
Observer
Observer
Worked for me! Thanks
C.Nicks
Also note a shortcut to the right-click "change:group" is to hold CTRL/CMD and right click.
Best Regards,
Cameron
Eagle Library Resources
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
