I used eagle free version for a while till I realized its limitations regarding the board size. I bought the subscription for a month to use eagle standard edition. I received the email with the serial number after 40 minutes. However, after a day I still do not see Eagle being listed in my Products and Services. So far I have lost one day out of a month subscription. I tried to search in autodesk website to find out how I can activate my eagle to no avail.
Please let me know how I can activate my subscription. Also, It is only fair to start the subscription after the activation.
Abtin
@Anonymous wrote:Hi,
Abtin
Email with a serial number? That doesn't sound right for EAGLE v8 as it's all done over the internet by logging into your Autodesk account. Go to the EAGLE control panel and choose sign out from one of the menus and then sign back in again. This should force it to re-check your entitlement from the Autodesk servers and should enable your subscription license.
Best Regards,
Rachael
Hi @Anonymous,
Welcome to the Community.
There was a sync issue that occurred in the order, which we've already fixed just now. You should now be able to view and access your EAGLE Standard subscription from your Autodesk Account. Kindly try to log back in to your account to verify the updates made.
I hope this helps, let us know how it goes. Thank you.
Fantastic! Can you spend 5 minutes into looking what is the problem with Farnell being unable to deliver Eagle licenses?
Hello !
I'm facing exactly the same problem as @Anonymous! My license was bought on may 30th and i've got no clue how to activate my product, although I did receive an email with a serial number and product key (from autodesk).
It does sounds like a problem between Farnell and Autodesk, but as a user, if I can buy a license, it should be way easier to activate it. We're losing precious days of work, and that's not a good news.
I already contacted the support but i'm still waiting for an answer, so i'm knocking at this door... Who knows? 🙂
Have a nice day
Arnaud
Hi there, friend! My order for Eagle sits with farnell since 12th of may, so I'm finding workarounds to proceed in my design... hard, but manageable so far.
Well, since Eagle 8 is entirely login-based user verification, all you need is NAME and PASSWORD for Autodesk login, so if Farnell sends you serial number, they REALLY may be retarded, I think I told them in the 15th of may or so that the new accounts work entirely as a login.
All you need to do is to "Log out" under the project window, then log in with your Autodesk Account that has the eagle license. And that should be it.
Farnell is now known over the years to be SERIOUSLY understaffed of people responsible for any kind of decision making and customer support, maybe the person responsible for the Eagle management and such has been fired a year ago, nobody knows.
Try this trick: go to your farnell, click on the specific eagle you have ordered, then click on "See stock and delivery dates", what does it say? Mine says 5th of June.
Anyway, I agree with you, this is retarded.
Thank you! Thanks to you, everything is know working.
the main problem — and what makes it so difficult to work out — is that the license was associated with the email address, en therefore account, used on Farnell. But in my case, the Farnell account belongs to the purchase manager, and not to me as a developer.
So I had to ask to my purchase manager to give me access to the license I asked him to bought. That's kind of weird but hopefully, as I said, everything is now working.
The solution would then be, for the renewal of the license or when buying a new one, to buy it directly from one of our developer address, but that's not exactly how we where expecting it to work.
That being said, we're maybe too complicated. Let's say that's the European charm 🙂
Thanks again for your helpful time,
Have a nice day,
Arnaud
On our Farnell account, they just say that it was to be delivered by a third party. The next day we received the mentioned email from Autodesk, which was, I guess, the "3d party delivery".
Sounds weird that they told you you'll get it on the 5th, since there's no real "stock".
All the same : the whole thing was weird.
I hope you'll get quickly a real solution!
Have a nice day,
Arnaud
@Anonymous wrote:
Im having the same problem that the one stated above.
I purchased a monthly subscription for eagle but i'm still seeing the licence as free.
The product is not listed in my product list Either.
Can anyone help me with this? I need to get rid of the dimension limit asap.
If it's not showing in your product list then your order hasn't gone through properly and something needs sorting at the Autodesk end. Your best bet is probably to email eaglesales@autodesk.com and explain the situation.
Best Regards,
Rachael
Same problem here with v9.2.2 (with the exception of no email received).
I paid this an hour ago and it's still processing. Why this isn't AUTOMATED yet?
Z
Hi @Anonymous,
I hope you're doing well. It actually is automated, in some cases I've seen it take a few hours to process most of the time it's near instant. It should be available by now, please let me know if it isn't.
If it is available, make sure to sign out of EAGLE and then sign in again to make sure the subscription cache refreshes and you get your license entitlement.
Best Regards,
I purchased a years ful subscription for EAGLE and I lost both of my computers that ran the software. I bought two new machines and installed Eagle, but it no longer appears in my Account so I have no way of activating the new installs and as such the software is in the Free trial mode.
How do I see my subscription in my Autodesk account so I can get this resolved? THis is very frustrating
I am facing the same problem. I bought the subscription on 15th April and still, I am not able to access the standard version. Kindly look into this. I am using it for my work and as it is getting delayed, it is costing me. Even after generating tickets, no proper response was received. There is no contact number to directly report the problem. Please do something ASAP.
