The future of Electronics at Autodesk is Fusion, click here to visit the Fusion Electronics forum. Eagle and the Eagle Community will be End of Life on June 7, 2026 - click here to see the announcement.
CAM Processor DXF export upgrade
garnav
Observer
garnav
Observer
Observer
I'm trying to figure out CNC milling process with Eagle. The first step is to get some vector files that I can use in the CNC software I'm the most efficient with which are the software from vectric (no offense here but I found Fusion too confusing for now)
Well the best way I found is to export DXF drawings from the CAM Processor.... but it doesn't work in version 9.6.2 because of the "pad bug" (described in this forum) this have been corrected within Fusion since Eagle has been eaten by big F but... I still don't get all the information I need since soldermask layers are not exported in the dxf.
Also tried DXF export from the file menu which link to a totally obsolete ulp, mill_outline.ulp which generated HPGL with precalculated mill trajectories (I cannot read HPGL with vectric and I do not want precalculated trajectories). Flatcam was meant to do the job from gerber but it doesn't read Eagle Excellon correctly. Some tutorial point to 3D export to render each curve manually which seems a total lost of time and ressources. Printing to pdf have a bug with plan polygon and the filling is done with lines which is a pain to remove.
So the question is : "Is there a simple way to export clean layer vector informations from Eagle ?" if not is it possible to add soldermask to the dxf drawing cam processor ? and even better do you plan to correct this output in standalone version of eagle (even if we add to copy some dll directly from fusion to eagle software)...
Sincerely
Sylvain
jorge_garcia
Hi @garnav,
I hope you're doing well. Try running the dxf.ulp that comes with EAGLE. This one will export whatever layers are currently visible in your layout. That's probably the simplest way to get you what you need.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
garnav
Observer
Observer
Actually that's the worst export I can have, totally unusable to generate toolpath. I've tried many option and ulp before going for the CAM Drawings DXF.
Export via PDF printing > generate file based on graphics result, outlines and line width not handle correctly
mill-outline.ulp > doesn't handle plane, modify your geometry
CAM drawing DXF in Eagle 9.6.2 > almost ok but pads are note merged correctly on top layer
CAM dxf 9.6.2CAM dxf 9.6.2
CAM drawing DXF in Fusion 360 > everything ok but it miss soldermask layers
CAM dxf FusionCAM dxf Fusion
dxf.ulp > generate graphical correct files but not usable for toolpath generation
DXF ULP option 100DXF ULP option 100DXF ULP option 110DXF ULP option 110DXF ULP option 111DXF ULP option 111
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
