BUG: Single Layer Mode Modifying Color Chosen
C.Nicks
Advisor Advisor
C.Nicks
I've noticed that in single layer mode the palette color chosen for the "Dimmed" setting is not showing correctly.
As you can see from the image, single layer is dimming the color chosen. I thought single layer mode didn't even work because it was showing black for my grey setting.
The color should show exactly as it is in the palette.
Best Regards,
Cameron
Eagle Library Resources
C.Nicks
Now that I've been thinking about it, I would like the dimming option to use a single alpha value and a greyscale checkbox. That way you could just set the dimming to reduce the transparency of all of the layers, and still show some of their colors.
Best Regards,
Cameron
jorge_garcia
Hi Cameron,
I've pinged the devs on this. Thanks for the feedback.
Please let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
ben.leduc-mills
Thanks for bringing this up, Cameron. Improving the color picking / palette experience in general is definitely something we need to work on. I'll make a note about this issue specifically and see if we can clean it up. Thanks!
