EAGLE Forum
Welcome to Autodesk’s EAGLE Forums. Share your knowledge, ask questions, and explore popular EAGLE topics.
Blurry text labels/Display settings
6 REPLIES 6
1596 Views, 6 Replies
I am experiencing a similar blurriness/resolution issue as a number of people in the support forums reported about a year ago. When I place a part, such as an IC, the text labels are blurry and illegible, especial when zoomed out. I tried unchecking the Enable High DPI Scaling and Auto Screen Scale Factor options, which fixes the problem of blurriness completely, but any of the menus/parts search is so small I can't read anything. I also boosted the icon size to 45 when I did this so they are fine, but all the other menus/inspect etc are impossible to read.
I also tried running the program with the nvidia graphics card, changing various application preferences (right click on app, preferences, compatibility, Change high DPI settings) and tried just about every possible configuration there, as well as toggling the windows option to fix blurry apps. Nothing seemed to make any difference.
Here are my settings with the Display DPI options checked, icon size 20, and what it looks like in the schematic view:
UI settings (when DPI options are checked)UI settings (when DPI options are checked)Schematic (when DPI options are checked)Schematic (when DPI options are checked)
Here's what it looks like when the display options are unchecked (this is a 15" display so this is really really small):
Unchecked DPI - SchematicUnchecked DPI - SchematicUnchecked DPI - control panelUnchecked DPI - control panel
I am running:
Eagle 9.5.2
2018 HP Spectre x360 convertable 15" laptop
16GB ram
Intel i7-8550U 1.89/1.99GHz
Windows 10 Home 64 bit (1809)
Intel UHD Graphics 620 AND NVIDIA GeForce MX150
recommended Windows display settings are:
3840x2160 (also only option with correct aspect ratio)
250% scaling
Thanks for any help! I have tried everything that other similar/older forum posts suggest already and none of it has worked. It sounded like that was occurring for people on V9.0 and 9.1, and has since been fixed, so I'm not sure if it is the same problem exactly. Fusion 360 seems to scale much more appropriately, I haven't had the same issues with it.
6 REPLIES 6
jorge_garcia
Hi @Anonymous,
As you have found this is a current limitation with EAGLE and high resolution screens, you can try different combinations of things to find a compromise but nothing is really ideal. This should be resolved in the next few months.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
in reply to: jorge_garcia
Thank you! This is helpful. I was able to find some settings that were passable, but I had to toggle between the High DPI options being on and off depending on whether I was inserting components or editing their placement, which means restarting the program each time. Really looking forward to the proper fix, it's great to hear that we can expect it later this year.
Thanks for the information!
It's been over half a year since your reply. This issue was presented to the forum by several other members, over two years ago. What's hampering the fix? Why has so much time passed without the issue being fixed?
Someone else elaborating on the issue and also asking if the issue is actually being worked on:
https://forums.autodesk.com/t5/eagle-forum/resolution-problems-in-9-1-1-windows10/m-p/9041735/highli...
a.soriaVBFYE
Same problem. Is there any solution ?
High DPI displays are not new.....
Thanks.
RHAD1969
in reply to: a.soriaVBFYE
Same issue here.
Where is the fix?
richardUWHCK
Same issue still here
Technology Administrators
