Hello everyone,
I've been using Eagle for a few years now. however in the new eagle 9.2.x version the board manager always seems to lay the selected layer on top of all the others so say for example the bottom layer is selected either by routing a signal on it or by manually selecting it in the menu in the upper part of the screen it's displayed on top of the top, the silkscreen layer and all the others. this is quite annoying because you don't get that well of an overview when for example finishing one signal path. And in some cases, it can be confusing when the bottom layer appears on the top because it gives the designer the impression, that it now is the top layer.
My question now is, whether or not there is a way to disable this "feature"
thanks a lot in advance
Nikolaus
Solved by havlicek6TH3H. Go to Solution.
they already know about it. So try to wait and I believe that they will handle this beahviour.
Best regards
Vojta
Hi, I guess I'll have to wait then. Does anyone have any suggestions in the meantime on how to overcome this issue?
thanks
