- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
A couple of changes that should be done:
1) Add an update feature.
Eagle already checks for a new version, and lets me know when one is available but then I have to download, install, and then uninstall the old version. This is not always a problem but if I forget to move my custom ULPs or DRCs from the old to the new... UGH! This brings me to the next idea...
2) During install, have Eagle locate the ULP folder into the /user/documents/eagle folder so that #1 does not become an issue.
3) During install, have Eagle check for previous versions and if found, give the option to uninstall or just move content to new version.
4) Have Eagle represented on the Autodesk Update background program. I use a LOT of Autodesk products (I am a student and trying to learn as much as I can about CAD / Circuit design). It would also be great if either the Autodesk Update program, or if you created another program that, could act as a quick launch i.e. have a small taskbar with icons for all Autodesk programs installed. You could even provide ghost icons (greyed out) for those programs that are NOT installed but are available. Some people are not even aware of all the products you offer and this would be a great way to show them what is available.
