Running a CAM job from command line
Message 1 of 10
Hello all,
Is there any way to run a CAM job in "headless mode" through the command line arguments?
I understand that the -X brings up the CAM processor dialog, but I would like to load a specific file and hit the run button automatically.
Thank you for your answers in advance!
Replies (9)
Message 2 of 10
jorge_garcia
Hi @Anonymous,
I hope you're having a great day. I was trying to copy directly from the manual, but for some reason the PDF isn't letting me copy. Check section 10.3 of the EAGLE manual pg 327. It actually has examples on creating gerber files from the command line.
Let me know if you have any other questions or concerns.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 3 of 10
Hello Jorge,
We might misunderstood each other. The CAM processor has the ability to save a configuration to a *.cam file (called CAM job in the terminology I think). I would like to execute the contents of a *.cam file from a single command line command line call.
By looking through the cam file structure it would be straightforward to generate the command line parameters for each CAM task in  the job, but I would still consider that approach a hack, because there should be a way to execute a *.cam file directly from command line.
Message 4 of 10
I would still greatly appreciate a "yes it is possible"/"no it is not possible" answer to my question.
BTW this question was asked 8 years ago back in 2009:
http://eagle.userchat.eng.narkive.com/xNZ1U1vG/automated-release-script#post3
Message 5 of 10
jorge_garcia
Hi @Anonymous,
I hope you're doing well. At this point in time the only solution is the one that has been mentioned and is in the manual, the "hack" approach as you referred to it.
There is no way to run the CAM processor with a CAM job from the command line currently. However I will bring this up to the devs since I do agree that this should be possible without having to make a call for each file.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
Message 6 of 10
Hi Jorge,
I am doing well thanks I hope you are too!
I appreciate that you are forwarding this to the development team.
Please keep us posted about the results!
Any status update (idea accepted, put to the backlog, whatever) would be welcome.
Thanks again and have a great day!
Message 7 of 10
Hi Jorge,
Do you have any feedback from the development team regarding to this feature?
Message 8 of 10
jorge_garcia
Hello @Anonymous,
I hope you're doing well. I don't have any news on this front other than the CAM processor has now been taken over by a different developer whose main focus right now is fixing issues with the current implementation. Once those are resolved then we will look into new functionality.
I'll ping him on this thread that way he is aware of your request.
Best Regards,
​Jorge Garcia
Message 9 of 10
Many thanks for the update and good luck for the developers for the bug fixing!
Message 10 of 10
