Jorge,
Thanks, I should of mentioned that I did try that earlier in my investigations without any difference in output. For the record, I have entered this:
$ /Applications/EAGLE-9.1.1/EAGLE.app/Contents/MacOS/eagle -X -N -dCAMJOB -j/Users/username/development/circuits/projects/pname/../../cam/ -g4layer.cam -o/Users/username/development/circuits/projects/pname /Users/username/development/circuits/projects/pname/pname.brd
error while loading JSON:
Error open file /Users/username/development/circuits/projects/pname/../../cam/
Canceled (option '-N' was given).
What seems fishy to me is the error open file gives the right bit of pathing, but no matter what else I specify for other arguments, I can NOT get it to pick up the *.cam files I am point it to. I've even tried the JSON block as a string on the command line with no luck (ATTACHED as autodesk_support.txt) .
As for using the older style of CAM operations, this is initially why I am wandering down the path of this forum topic. This approach is how we have been doing this for years. Now, as of version 9.1.1, we get the following with no generated output results:
> /Applications/EAGLE-9.1.1/EAGLE.app/Contents/MacOS/eagle -X -N -dGERBER_RS274X -oTop_Copper.gbr /Users/username/development/circuits/projects/pname/pname.brd 1 17 18
This 'older' command exits with no error only on versions 9.1.0, 9.1.1, but I can't find any output files generated. This 'older' command works fine with Eagle 7.7.0 up to Eagle 8.6.0. Eagle version 8.6.1 and up (until 9.0.1) gives a Segmentation fault: 11
I would much rather look forward than backwards on this subject.
- Matt
