Library updated in 8.x causes 7.7 to crash
sphillipsT3N7F
sphillipsT3N7F
I have been using the new licensed version of Eagle (8.4.3 currently) since it came out and have been happy with many of the improvements, however many of my coworkers who do less PCB design are still using 7.7 as we only have a single license of 8.x. We have found an issue today when sharing a common library (which has had a number of parts added in my 8.x version) with a 7.7 version. When the library was updated (Library -> Update...) Eagle crashed, it is difficult to tell exactly what caused this, however a dialog box appeared mentioning the "unknown attribute 'keepoldvectorfont'" which most likely has something to do with it. We have attempted this a number of times now and have had the same result each time, we are running eagle 7.7 on Windows 10 64-bit.
Being able to update, share and modify a common library between these versions is absolutely critical to our ability to continue using Eagle as our CAD software.
Can anyone please provide insight how we can recover from our current situation.
Chad
jorge_garcia
Hi Chad,
I hope you're doing well. The easiest solution would to save the library in a 7.7 compatible format. Open your library in 8.4.3 and select File > Save a Copy in 7.7. Pass that to your coworkers and see if it works.
Keep in mind that if you must maintain compatibility with your co-workers you shouldn't make a managed library since V7.7 has no clue how to deal with it.
Please let me know if you continue to run into problems.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
