10:56 AM
Hi
When you click on "Line" there is a box in the tool bar that allows you to choose a line "Width"... There is a pull down box with about 10 or so entries to select from... Are these values stored in a file somewhere so that the list can be edited to contain just the values that you actually use regularly? I know you can add values to the list, but it would be nice to delete the ones that are never used so that only the used values are present.
Bill
