EAGLE Version 9 is here! Nothing short of awesome!
matt.berggren
Alumni Alumni
Message 1 of 21
matt.berggren
Greetings EAGLE Community!
Let me be the first to proudly announce the release of EAGLE version 9!  This is a whopper of a release with more muscle than anything we’ve ever attempted in the past. (And I promise that’s not just hyperbolic; we have really stuck a flag in the ground with this one!)
With this release - which all of you subscribers are eligible for (no upgrade fees with subscription!) - we have introduced new ways to wire your schematic, route your board, new tools for cleanup & new ways to make designs look awesome!  We have added new tools for navigating your design and new approaches to locating objects and launching commands. We extended the 14-day offline limit to 30 days to ensure you aren’t stuck in a dark corner of the globe, cursing the EAGLE development team.  🙂
As you know we put a ton of energy into EAGLE and I would ask that if you can support the development by subscribing to either the Standard or Premium versions ($100 or $500 respectively) that would be amazing.  If you drop off, it’s cool, your designs will continue to open and you can always generate outputs, etc. (Zero lock-in!) Subscription is how we pay the development staff and your support is an important vote of confidence that keeps us doing what we’re doing every day, trying to deliver amazing value!
Ok, that said read-on...And stay tuned for emails with links to the What’s New webinars slated for the coming days and weeks!  This one is a doozy! And we’re just getting started!
Quick Connect
With this release we are including a new range of tools for schematic wiring collectively named Quick Connect.  This is an ongoing project so expect this is the first (albeit significant) step on the path toward some really special and highly unique features to make the pain of schematic wiring easier.
Buses
(Yes, we’ve heard…”But I never use buses”.  Hear me out, please…I promise this is awesome!)
With this release we’ve completely overhauled buses and the bus properties dialog, with the changes here making it MUCH easier for you to generate groups of signals and move them around the design in more abstract ways (think:  bundle of signals called ‘UART’ or ‘LCD’ instead of 16 wires to name and label every time!).
And while we knew it was great to be able to create buses, if you were going to go to the bother of making them, we should provide the tools save and reuse them.  So with EAGLE v9 we’ve also added the notion of Persistent Buses.  Now you can quickly create an SPI bus, save it once (with all of it’s signals) and recall it design to design, sheet to sheet, etc.  You can even embed signal ranges in the buses for things like multiple chip-selects you might require on an SPI bus.
Cool?  Wait, we’re not finished!  🙂 If we only improved buses but not the signal handling going into and out of buses, we would be missing an opportunity, so with EAGLE v9 we have also included tools to breakout buses quickly and easily, into individual nets and we will automatically generate the wires and single names & labels to make this whole process much, much smoother.
Have a look at the following video for more details:
Quick Connect - Breakout++
We didnt stop with buses or bus breakouts.  The Quick Connect tools now allow you to quickly breakout component pins as well and will again, automatically generate wires with names and labels to make building designs so much cooler than ever before!
Quick Route
With the addition of Quick Connect we felt it was a little unbalanced and thus we’re also announcing the addition of the new Quick Route tools in PCB (why should schematic get all the fun?).  These are long overdue additions that will blow you away with their speed and simplicity.  As you’ll see in the video below, quick route is fully integrated in the routing tools you’re familiar with and replaces the oft-unused and overly complicated Follow-Me Router.
With Quick Route you can single-click an airwire and route the from-to, a complete signal, even a differential pair.  Hit “Enter” while routing and Quick Route will complete the connection.  Quick Route also includes Bus Routing for multiple signals...even multiple diff pairs.  The Bus Router will enable short work of groups of signals and works hard to join the tracks together in a way that feels totally natural.  Check out my video below and try not to cry...I was stunned at what the team pulled off and again, we are only getting started!
Design Manager
Ok folks, we heard you.  Navigating a design in EAGLE (especially a complex design) needed work.  Locating devices, signals, their individual net objects like pads and vias was painful.
Finding an uplaced part and moving it on to the board...Selecting all the tracks in the GND net and increasing their width...Grabbing groups of parts and aligning them or moving them or rotating them without fishing for a reference point...All of this could be improved!
With EAGLE v9 we present the Design Manager, giving you a top down view of your PCB like never before.  Locate objects, launch commands like Quick Route or Ripup, grab groups of items and apply changes using the Change command.  The Design Manager makes all of these processes easier and I’d encourage you to check out the video below.
Smash -> Reposition Attributes = Component Text Handling on Steroids
The all new Reposition Attributes command replaces the old Smash tool (the command still works...rest assured) and takes the notion of unlocking and positioning component text to a totally different level!  Have a look at the video below to see how selecting the attribute type and specifying the location ‘around’ the body of the part, this new command allows you to now click...click...click to place text in positions that make sense, aligned magically around the body of your parts.
Ripup -> Ripped up and redone
This latest release also introduces some pretty significant changes to the ripup command that will make many of you happy.  No longer struggle to hide all of your polygons or ripup all the connections on the board. Or more precisely, ripup things like connected copper or the copper in a signal on a specified layer.  All of these are now opitions with the new ripup tools to make cleanup and rework of a design MUCH easier. Again, checkout the video and let us know what you think.
Outtro
With that, I’ll leave the rest of the details to the blogs, what’s new videos, release notes, these forums and more.  Look for more videos, more content and of course more new things. Please join me in thanking the development team for this AMAZING release.  And for our trusty support teams, marketing org, and everyone else for making sure you know what’s there and how to use it.
Best regards,
Matt Berggren
Director - Autodesk EAGLE
Replies (20)
Message 2 of 21
hello,
Sorry for putting my question here, but I think this can be a good start to ask here. So I was installed the Eagle-9.0.0 few hours ago, and when I was started to use, I was surprised that the "Follow me" routing option is gone. I was searching and find finally this post about the news of this Eagle version. I saw the related video about the new routing features. This is grate, but when I tried to make a route with by "Quick Route Airwire", the tool made the route only that layer what was set, and of course the path was not "perfect" for me, what the tool made, and I tried "move" the route but everything was kept on the layer where the route was made. This was wrong to me, because my route movement as crossed few routes, but I was expect to change the layer, but it was not happened.
I am pretty sure, I am doing something wrong, but is it possible to do the similar thinks what the "Follow-me on both side" feature did in the older version? I mean do the route by hand but together with the tool.
Thanks for your help,
/Robi
Message 3 of 21
mark.roszko
Any ULP improvements yet?
Message 4 of 21
JacksonAudio
This update....
Message 5 of 21
jorge_garcia
Hello @mark.roszko,
I hope you're doing well. Nothing yet on the ULP front but stay tuned.
Let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 6 of 21
JacksonAudio
BUG - pressing and holding the layers button to access the layers presets results in the error "Unknown Layer 0" when a preset is selected.
Message 7 of 21
jorge_garcia
Hello @Anonymous,
I hope you're doing well. The follow-me router functionality was replaced by the Quick Route functions. The follow-me router has several shortcomings that made us move away from it. The closest thing you can do with quick route now is manually start a trace and then once you feel that you want EAGLE to finish it for you press the enter key and quick route will automatically finish the trace.
We are going to make even more improvements to these functions so over time it should get to a point where you won't miss the follow me router.
Please let me know if there's anything else I can do for you.
Best Regards,
​Jorge Garcia
Message 8 of 21
jorge_garcia
Hi @JacksonAudio,
I can't reproduce this. Could you start a new thread and include a short video showing how you get the error. If that's not possible then a detailed procedure to reproduce would be super helpful.
Thanks for reporting this.
P.S The Prism looks AWESOME!!!
Best Regards,
​Jorge Garcia
Message 9 of 21
matt.berggren
We'll make improvements to the scripting system in time, for sure.  Our hope would be to introduce something cleaner than the ULP language in the SW today.  I wont hint at what we have planned there because it's too early in the process but we are of course very much interested in your input!  🙂 . Feel free to create a thread about ULP requirements and I'll be happy to dive in and chat about them!  (dont want them to get lost in this post!)
Best regards,
Matt
Message 10 of 21
JacksonAudio
I am able to recreate new presets and they do work so it's not a total loss.
Message 11 of 21
matt.berggren
HAHAHAHAHA...Brightest point in my day!  🙂 . Thanks!
Message 12 of 21
I think the video for Design Manager is a duplicate of that for Quick Route. For those of you who want to check the correct video, please visit here
Best,
Chad
Message 13 of 21
matt.berggren
Thanks Chad! I think they are all basically triggering the Playlist! So they roll into one another. I will tidy up the post but thanks for posting the link! Best regards,
Matt
Message 14 of 21
JacksonAudio
Truthfully, since I deleted all my previous presets and created new ones....I'm not able to reproduce it either. Thanks for the kind words about the PRISM. It was all designed in EAGLE. 🙂
Message 15 of 21
mark.roszko
Don't take this the wrong way but I had to post it:
https://forums.autodesk.com/t5/eagle-forum/eagle-9-amateur-level-ui-problems-seriously-wtf/td-p/7949...
It's like the EAGLE team did zero testing on Windows
Message 16 of 21
marthinek
Hi EAGLE Team,
I couldn't find any other form of contacting you regarding the new version.
I just have updated to the new version from 8.3.1... and it doesn't work at all. I can't open my projects and even expanding the folder structure takes forever..
When I switch to old version, everything works perfectly fine.
Moreover, the font type in Control Panel in the 9.0v  is incoherent.. (each project name is different)
Quite a disappointment...
Marcin
PS. I'm working on Win10 x64
Message 17 of 21
engineeringNCMXB
Quick Route is REALLY handy [almost]....but how do you specify the trace width? All the time it saves is lost if I have to manually change the width of every track segment.
Lot's of new and apparently really useful tools to learn. Really happy to see the efforts becoming reality.
EDIT: It is defined in the NET CLASS, which is ok as a default - but I would love to see the option of picking a width on the fly.
Carlos Acosta
Factory400 - YouTube|Instagram
Message 18 of 21
jorge_garcia
Hello @marthinek,
If you can please start a new thread with these details and any additional ones you can provide. I don't want this to get lost in this thread.
Best Regards,
​Jorge Garcia
Message 19 of 21
Thanks for sharing new Eagle version video.
Message 20 of 21
daniel1991ro
Why don't you consider to create a "Devices" folder for each library? I think the libraries will look more organized and the it will be more easy to work with them.
A library with a few packages and a few symbols can have many devices. For me at least, scrolling down trough more than 100 devices until I reach the Packages or Symbols category  inside a library is very annoying. I don't think it's a huge deal to implement this in the next update.
In this example I highlighted  only a library which contains 3 devices but try to do this with "con-amp.lbr" 🙂
I hope someone will agree with me: please put all the devices in a subcategory called "Devices" as you did with "Packages" and "Symbols".
eagle.PNGBR<
Daniel
