Eagle 9.1.x won't start on Windows 10
thomas_modliba
Message 1 of 93
thomas_modliba
I got a new notebook and tried to install Eagle, first 9.1.0, then 9.1.3.
On first start I need to enter account data and last verify with SMS code.
Then window disappears and nothing happens.
When I try to start Eagle, sometimes there's the splash-screen, but no program window opens. I can see in task manager that eagle .exe quits after some seconds.
Already deleted c:\Users\USER\AppData\Roaming\Eagle\subscription.v1 - start over wiith verification and same issue
So I am not able to use the program. Any ideas to fix it?
Replies (92)
Message 41 of 93
Thank you
I have solved my problem too.
Message 42 of 93
I have installed Eagle 9.6.2 today on Windows 10 Home on my Acer Swift5 with integrated graphics (Intel). The program does not start up. When I run the application, the splash screen appears, then nothing. It is not even present in the Task Manager. I looked up for the file mentioned in the above post, but unable to find the file. Request your help.
Message 43 of 93
jakkennedy
As I deleted the file I can't be sure but I'm sure it was in the install directory.
In answer #36 they posted "Faulting module path: C:\EAGLE 9.6.1\LIBEAY32.dll" although if you chose a different install directory you might want to look there.
Or just install KiCad which is what I have decided to use for now. 😉
Message 44 of 93
Katherine_Tomczynska
Observer
Observer
See message 22 for instructions.
Message 45 of 93
Those links don't work anymore. I wound up removing the libeay32.dll file out of the Eagle directory and now it works. I thought I had to replace the file, but just deleting it seems to have fixed it. New install of Eagle 9.6.2 on a fresh install of Windows 10 Pro. Eagle would display loading, then go away and never load.
Message 46 of 93
Two years later and still works.
Thank you
Message 47 of 93
thomas_modliba
I rather wonder why this still isn't fixed since two years 🤔
Message 48 of 93
zachCS2B7
Wow, this was still an issue when I installed 9.5.2, and it's still an issue with 9.6.2 eight months later.  Same solution worked.
Message 49 of 93
Bruh, I don't know why that worked, but thanks!
Message 50 of 93
It's now the end of 2020 and I still had to replace that .dll file to actually get eagle to startup and run on one of our machines. Kinda ridiculous...
Well, guess we'll be looking for other software solutions already
Message 51 of 93
paulmullen5FHHD
By the way, since the original solution was posted, the file structure has changed a bit, but look for the win64 version of the zip files and you'll get the dll you want.
Message 52 of 93
I've tried various versions of the libeay32.dll file including deleting it as another contributor tried, but I can't get Eagle 9.6.2 to launch.  It just sits at the splash screen, with loading.... at the bottom left hand corner.
Message 53 of 93
It doesn't work for me either. What with this?
Message 54 of 93
I have the issue please assist me @ [email protected]
Message 55 of 93
It was a graphics card in the old NB LENOVO T60.
Message 56 of 93
Same issue I am facing.
Could anyone tell how to resolved it?
Message 57 of 93
Thanks for the solution.
The issue has been resolved.
Thank you so much.
Message 58 of 93
i am using the eagle 9.6.2 and it has the same problem but after your solution i got relief from severe pain. Thanks a lot and no word to express my feeling for you. Thank you so much.
Message 59 of 93
I was working on some project in Eagle, and it crashed. Now the Eagle won't open and every time I am launching Eagle it's asking me whether I want to load the board as well from the project I was working from. I have tried installing it again and replacing dll files as mentioned in this discussion but it didn't work for me. I will appreciate any help.
Thanks!
Message 60 of 93
I didn't find this file "openssl-1.0.2p-x64_86-win64.zip" in this link "https://indy.fulgan.com/SSL/" anymore. Can you help me, please?
