Eagle 9.1.x won't start on Windows 10
thomas_modliba
Message 1 of 93
thomas_modliba
I got a new notebook and tried to install Eagle, first 9.1.0, then 9.1.3.
On first start I need to enter account data and last verify with SMS code.
Then window disappears and nothing happens.
When I try to start Eagle, sometimes there's the splash-screen, but no program window opens. I can see in task manager that eagle .exe quits after some seconds.
Already deleted c:\Users\USER\AppData\Roaming\Eagle\subscription.v1 - start over wiith verification and same issue
So I am not able to use the program. Any ideas to fix it?
Replies (92)
Message 21 of 93
thomas_modliba
New 9.2.1 doesn't change the situation .
Still the only chance is to use 9.0.1, delete subscription file and go through registration prior every use. Really silly and meanwhile I really hate the stupid SMS code verification.
Message 22 of 93
thomas_modliba
I had a chat with Jorge from Autodesk support and he solved the two issues for me.
1. Replacing "libeay32.dll" in Eagle install directory by version coming with OPENSSL did the job. Eagle now starts as it should.
https://wiki.openssl.org/index.php/Binaries links to https://indy.fulgan.com/SSL/ (second link) where we took "libeay32.dll" out of "openssl-1.0.2p-x64_86-win64.zip"
2. disabled 2 facor authentication under security in account settings - now E-Mail and password does the job.
Thanks to Jorge for taking the time and solving the issues
Message 23 of 93
Thanks for your update.
I followed the instruction, and I solved my problem too.
Thank you so much !
Nicholas
Message 24 of 93
thomas_modliba
Thanks to Jorge and hopefully that this will be fixed in future versions
Message 25 of 93
Thank you so much Jorge, this was a perfect fix. Thanks for taking the time.
Message 26 of 93
This worked for me too.  I'm running EagleCAD 9.2.2 on a Kodlix N42-D MiniPC, and I couldn't get past the splash screen until I replaced libeay32.dll.  Thanks!
Message 27 of 93
Remove "libeay32.dll" from the folder where the eagle is installed. Then you will be able to use eagle well.
Message 28 of 93
Worked like a charm. Thanks for the solution! 🙂
Message 29 of 93
Katherine_Tomczynska
Observer
Observer
Had the same problem today with a brand new HP Laptop and Eagle version 9.5.2, and the above fix worked great, although I used openssl - 1.0.2t-x64_86-win64.zip
Message 30 of 93
It's been a year and a half since this was originally reported and the problem still exists in new downloads on fresh Windows installations.  I just had to do this again.  When will it be fixed?
Message 31 of 93
zachCS2B7
Thanks for the solution!  I used it today with EAGLE 9.5.2 and the file from openssl-1.0.2u-x64_86-win64.zip, and it worked.
Message 32 of 93
Removing the dll works for me;
Message 33 of 93
Thank you.  Fixed it for me too!!
Message 34 of 93
Worked well 🕺
Message 35 of 93
jakkennedy
Removing "libeay32.dll" worked for me too. You would have thought Autodesk could fix this.
Message 36 of 93
tpangburnXPG3S
Observer
Observer
I seem to be having the same problem. I noticed that in the event viewer I am seeing this error, but no crash dump.
Faulting application name: eagle.exe, version: 0.0.0.0, time stamp: 0x5e87e53e
Faulting module name: LIBEAY32.dll, version: 1.0.2.7, time stamp: 0x56d84c65
Exception code: 0xc0000005
Fault offset: 0x000000000000ca23
Faulting process id: 0x2414
Faulting application start time: 0x01d6201d2bae8ded
Faulting application path: C:\EAGLE 9.6.1\eagle.exe
Faulting module path: C:\EAGLE 9.6.1\LIBEAY32.dll
Report Id: fc86aefb-d522-46df-85fe-f9c75bc1ee46
Faulting package full name:
Faulting package-relative application ID:
Message 37 of 93
tpangburnXPG3S
Observer
Observer
Never mind I didn't see there was a second page.
Message 38 of 93
Worked. Thank you so much !
Message 39 of 93
jakkennedy
Although I fixed this with Eagle I now find some problem also exists with installing DWGTrueView.
My conclusion is the problem lies with AutoDesk and poor QC by the programmers working for the company who can't fix an at least 2-year-old installation problem that appears to have an easy workaround but that has to be sussed out by end-users. Management is also obviously sleeping on the job.
Message 40 of 93
Thanks!
Very concise solution.
Kind Regards
Tony
