Eagle 8.0 first launch fail
Message 1 of 60
Hi
I download and install Eagle without problems. However, I can not run for the first time the software
Accepted solutions (3)
Replies (59)
Message 2 of 60
note: Windows 10 with other Autodesk software installed....v7.7 is working
Message 3 of 60
Me too -- exactly the same problem.  Blank window frame, "Not Responding", have to kill it.
7.7 works fine for me also.
Win10.
Message 4 of 60
jorge_garcia
Hi ericwertz and wargo123,
This is unusual, can you guys provide more details about your systems? EAGLE was tested under Win 10 and we didn't have this issue.
I'll have one of our devs check this out.
Best Regards,
Jorge Garcia
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 5 of 60
my system is:
Lenovo y50
Intel I7 16gb ram Nvidia 960m
win 10
McAfee antivirus
Autodesk Inventor 2017
Autodesk Recap Pro
Office 2016
if you need any log please let me know.
Message 6 of 60
innovatenate
Autodesk Support
Autodesk Support
I just wanted to offer some generic advice in this thread in case it helps.
Anyone who is experiencing this issue:
Have you tried temporarily disabling anti-virus software?
Another option may be to add a specific exception in the settings for your anti-virus software for eagle.exe.
Instructions would looks something roughly like
1. Type “VirusScan Console” at the Start screen and press “Enter.”
2. Right-click “On-Access Scanner” listed in the left window pane and select “Properties.”
3. Click “All Processes, Detection, Exclusions” and select the “Exclusions” tab.
4. Click the “Add” button, click “Browse” and select the folder or file you want to add as an exception. (%program files%\autodesk\autodesk Eagle X.X\Eagle.exe  - this is a bit of a guess sorry if it is not exact)
5. Click “OK” in the “Add Exclusions Item” dialog box and click “OK” in the “Set Exclusions” prompt.
6. Click “Apply” in the “On-Demand Scan Properties” window and click “OK” to save your settings.
If you are running on Windows another tip may be to right click on the launch icon for Eagle and select Run As Administrator.
I hope this helps!
Nathan Chandler
Principal Specialist
Message 7 of 60
I am having the same issue
Intel i7 4790K
2 x Nvidia GTX 770
Windows 10
Office 2016
Fusion 360
Avast Antivirus
I have tried the following:
Run Eagle 8 as administrator
Disable antivirus
Disable windows firewall
Running GPU with and without SLI enabled
None of the above steps worked.  The application starts to open, checks internet connection and gives the Stopped Working error when attempting to open the login window
Message 8 of 60
no, no working
I remove completely the antivirus
Reinstall
and run as administrator.
Another detail is that my default explorer is not IE or edge. This looks similar to a bug of inventor year ago where it crashes before opening the license menu and it was something with net framework. If you don't find a solution I am willing to give you monitored access to debug this on my laptop.
Message 9 of 60
jorge_garcia
Hi wargo123 and others,
Is anyone here behind a corporate firewall that might require the use of a proxy?
Please reply if this is anyone's situation.
Best Regards,
Jorge Garcia
Message 10 of 60
I'm at home and using a standard DSL router. And I don't have any "fancy" letters in my username, so it's not that either.
-e
Message 11 of 60
jorge_garcia
Hi Eric,
Did you install EAGLE to it's default location or modify it to program files ( x86)? If you installed it to program files (x86) uninstall and then let EAGLE install to it's default location.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Message 12 of 60
That's the problem.  Apparently not only can it not handle non-ASCII characters, but perhaps not spaces in filenames either.
Ah, I miss the old MS-DOS days...!
thanks,
-eric
Message 13 of 60
I'm still having this trouble. Eagle is installed to default 'C:\Eagle 8.0'
I have tried uninstalling and reinstalling it.  Re-downloaded and installed to default.  Uninstalled and installed to 'C:\Eagle8.0' to remove the space.
Message 14 of 60
Me too I installed in C:/Eagle/ and not solution. How do you launch a product that can not be setup in a specific folder?
I am attaching the crash report....
Message 15 of 60
I have de same problem in Win10. Message : "Eagle a cessé de fonctionner ....".
Eagle version 7.7 work correctly !
Message 16 of 60
jorge_garcia
Hi Wargo, denis and others,
Let's explore a few other possibilities. Is anyone under any IT restrictions? Corporate Firewall or in any other way limited. If you have special characters in your name (accents, apostrophes, etc.) please adjust your account to not have them.
If you are behind a corporate firewall, then you will likely need a proxy in order to use EAGLE. Our next release will have the proxy functionality enabled to solve the issues for those with IT restrictions.
If neither of these scenarios apply please post again and we'll continue to work through them.
Please accept as solution if my post fully resolves or you issue, or reply with additional details if the problem persists.
Best Regards,
Jorge Garcia
Message 17 of 60
I am behind institute proxy. Port 80 and 443 are open.
Waiting for the next build to come.
thanks a lot Jorge
Message 18 of 60
I am on a home network.  I can try putting my system in a DMZ later tonight and see if that resolves the issue.
Message 19 of 60
MY user is "xxx xxx" with a space between as is a Microsoft account. I am in home network without a corporate firewall. is the space affecting the launch?
Message 20 of 60
jorge_garcia
Hi wargo123,
It shouldn't. When you login to EAGLE you are usually entering an e-mail which by definition(correct me if I'm wrong) doesn't have a space in it. If you are entering a user name try entering the e-mail you setup your Autodesk account with.
Does that work?
Best Regards,
Jorge Garcia
