Connection between EAGLE and FUSION360 sometimes lost
HarrySatt
Message 1 of 66
HarrySatt
Hi there
I work with the newest Version of EAGLE (9.6) to create my boards. After that I transfer the 3D Data to FUSION by activating the FUSION360 Tab at the right to PUSH to FUSION360. this works fine but now I found myself disconnected from the FUSION360 model in EAGLE altough yesterday at end of work the connection was working really fine. Now I have the create a new link or pull from FUSION which ist not what I want. If I have nothing changed in FUSION there should not be a need the recreate a existing link and PULL the design from FUSION360.
I think the link should not be lost.
Regards, Harald
PS: At the moment this is not a problem because the FUSION part is not used in assemblies. but then one might run into problems.
Replies (65)
Message 41 of 66
HarrySatt
Hi @junyuan.zhuJ4HVC
I opened my .BRD file that is not able to relink but did not find a "fusionsync" entry.
<!DOCTYPE eagle SYSTEM "eagle.dtd">
<eagle version="9.6.1">
Then I opened one of the files I have worked on a while ago that was linked to FUSION but had not been touched by the newer version of EAGLE and found the fusionsync entry.
<eagle version="9.4.2">
See below
<board>
<fusionsync huburn="a.cGVyc29uYWw6dWUyYTk2YjEy" projecturn="a.cGVyc29uYWw6dWUyYTk2YjEyI0QyMDE3MTEyMDEwNDg1NTQwMQ" f3durn="urn:adsk.wipprod:dm.lineage:o0AHLOz1Q-2fL2kWf4rjTw" pcbguid="0c4be5b5-68a4-4146-aa4c-8383ab4ecfbf" lastpulledtime="2019-08-09T06:26:21Z" lastsyncedchangeguid="88a00034-d6e8-5773-9cb1-5a0da2f51a3c"/>
<p
I hope that helps a bit.
Best regards and staw healthy, harald
Message 42 of 66
tim.rettmann
Now it works quite better. I will test this workaround in the next few days. I don't use the pull function, therefor I can't say about it. Thanks for the fast response!
Do you have any idea about the issue  3D rendering?
Message 43 of 66
junyuan.zhuJ4HVC
Hi @HarrySatt ,
Did you save the file after sync to Fusion?
If the file was not saved locally after the sync, the link will also be lost.
Otherwise could you directly send me your BRD file for us to have a quick check?
to: [email protected]
Thank you!
Junyuan
Message 44 of 66
junyuan.zhuJ4HVC
Hi @tim.rettmann ,
It is not possible anymore to render a PCB with silkscreen / canvas.
Could you illustrate more on your workflow for this? It should be using canvas as default for Fusion sync.
Thanks.
Message 45 of 66
tim.rettmann
My work flow:
1. Create an eagle project, incl. schematic and board file
2. Create a new fusion link / project and push all files (more than 95% of the libraries are managed)
3. Open it with fusion and go to render.
As shown in the picture, the piggy back board (black) ist rendered and the red PCB not. The silkscreen and stop mask are missing. One day before, the piggy back board have shown the same issue. Yesterday, I loosed all components in the 3D file of the piggy back board and then I generate a new fusion link / project. Than I have to place manually all three piggy back board again and remove the buggy revision.
Message 46 of 66
HarrySatt
@junyuan.zhuJ4HVC
I will create a new EAGLE design and test how it looks in the several states of design.
I send you on monday.
Regards Harald
Message 47 of 66
junyuan.zhuJ4HVC
With default or changed solder mask color, I cannot reproduce this issue.
Did you modify the solder mask color from the CAM preview tab?
Does it happen to all of the files or just a certain file?
Thanks.
Message 48 of 66
tim.rettmann
I changed the PCB color only over the manufacturing tab. It looks like I'm getting this problem at higher revision levels, e.g. 20 or less.
I have seen this issue for different PCBs.
Message 49 of 66
HarrySatt
@jorge_garcia @junyuan.zhuJ4HVC  @tim.rettmann
Are sure that this problem is related to the thread it is in?
If not it might be better to open a new thread for this issue.
Regards, harald
Message 50 of 66
davidTARW8
Sorry @junyuan.zhuJ4HVC , it took me a while to get back to this and test it, but the workaround works great!  Much better!
Thanks so much.  Hope we'll see this fixed in a new version of Eagle soon.
David
Message 51 of 66
HarrySatt
@jorge_garcia
Hi there.
during weekend I tried out some tasks but now it seemed that something has happend (was changed) because now I am able again to reconnect to existing fusion designs and also I only have to pull one or two times. Not perfect but much better. what I see is that I get holes and drills after pulling with an additional 0 width dimension circle which draws a filled yellow (in my case) circle at the position of the holes. another weird put not really problematic behaviour.
Regards, harald
Message 52 of 66
HarrySatt
@junyuan.zhuJ4HVC
Hi
I can now give you snippets of the .BRD file which was able to  be restored but after a few hours again did not get the link to fusion.
<board>
<fusionsync huburn="a.cGVyc29uYWw6dWUyYTk2YjEy" projecturn="a.cGVyc29uYWw6dWUyYTk2YjEyIzIwMjAwMzI1Mjc4NjUzOTAx" f3durn="urn:adsk.wipprod:dm.lineage:OpPOPR7-SAu-pWxAGJwzzQ" pcbguid="" lastpulledtime="2020-05-11T11:37:58Z" lastsyncedchangeguid="" latestrevisionid="34a4d2f1-198f-483b-9cac-f5924c8772f9" lastsyncedrevisionid="34a4d2f1-198f-483b-9cac-f5924c8772f9" lastboardhashguid="f4affc32-5851-4d3c-7fce-36551e1407f6" lastpushedtime="2020-05-11T11:38:36Z" linktopcb3d="%12"/>
<plain>
After saving the .BRD file (hence all) the snippet looks like this
<board>
<plain>
as you can see. the fusionlink tag has fanished. Although the link was there and working a few hours ago.
After this I am not able to relink to the existing design. Why I do not know.
So I close EAGLE. After ropening the project I was asked to relink to the existing design. Were able to PULL und PUSH again and the link to FUSION was Ok again.
snippet was like below. fusionlink here again.
<drawing>
<board>
<fusionsync huburn="a.cGVyc29uYWw6dWUyYTk2YjEy" projecturn="a.cGVyc29uYWw6dWUyYTk2YjEyIzIwMjAwMzI1Mjc4NjUzOTAx" f3durn="urn:adsk.wipprod:dm.lineage:OpPOPR7-SAu-pWxAGJwzzQ" pcbguid="" lastpulledtime="2020-05-11T13:43:23Z" lastsyncedchangeguid="" latestrevisionid="19b3313d-d29d-429d-a295-574d17bf65f2" lastsyncedrevisionid="19b3313d-d29d-429d-a295-574d17bf65f2" lastboardhashguid="a0b395cf-1363-2a62-bf45-c5d3fc64cc33" lastpushedtime="2020-05-11T13:50:03Z" linktopcb3d="%12"/>
<plain>
Now I am able to work until next EAGLE close or computer shutdown.
Regards, Harald
Message 53 of 66
junyuan.zhuJ4HVC
Yes, I am afraid you need to manually set the value for linktopcb3d before next update.
Message 54 of 66
HarrySatt
Yes. No real problem. You mean always resetting the link to the existing FUSION design. OK. I can do that. Waiting still for solved version of EAGLE/FUSION
regards, harald
Message 55 of 66
HarrySatt
@junyuan.zhuJ4HVC
Hi there.
Today I received the new update of FUSION360. Now nothing is working anymore. The links between EAGLE and FUSION are invalid and after PULL und PUSH I can not even download the design file. Horrible by the best. What happend?
Regards, harald
Message 56 of 66
mad.macs
I'm still running into this issue as well.
I started with a new design in F360 as a sketch. Created a 3D Board and pushed to Eagle. Added some components to the board and pushed back to Fusion and pulled back to Eagle. Changed the board outline in Fusion, Pushed and pulled again. Added some more components, went to push the and the link was lost, and had to create a new link to F360.
It seems like the adding of components is causing the link to fail in my case, looking back, this may have been what was happening with earlier designs.
Message 57 of 66
jorge_garcia
Hi Guys,
I've reached out to the developer to look into this again to see what's going on now. Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Message 58 of 66
junyuan.zhuJ4HVC
Hi @HarrySatt ,
Seems like this is a different issue.
Could you describe your detailed workflow, e.g. what was changed in Fusion, etc?
I could not reproduce this issue by simply pushing to Fusion then move a component in Fusion then pull and push in EAGLE.
Thank you!
Junyuan
Message 59 of 66
junyuan.zhuJ4HVC
Hi @mad.macs ,
Have you tried the workaround mentioned in https://forums.autodesk.com/t5/eagle-forum/connection-between-eagle-and-fusion360-sometimes-lost/m-p...
It will be fixed in the next EAGLE update.
Thanks.
Message 60 of 66
HarrySatt
Hi
I describe my workflow. First I construct my board in EAGLE and then PUSH to FUSION360. This normally works fine but sometimes the link to FUSION is broken on next day. than I normally PULL and PUSH and the problem is solved. But not always. As I use the FUSION model in an assembly and the link is deadly broken. meaning no connection possible anymore than I run into troubles because I can not delete the model because it is in the assembly an I am not allowed the delete a file used in an assembly.
this is horrible behaviour and I really think of switching to another layout program were the connecition between electronic design and 3D handling is solved.
I would be really sorry because I am with EAGLE since the beginning but now it is to much frustrating. I use more tome to resolve the internal program issues than I have time to word on my design. and my students see me struggling. that is more frustrating than ever.
Regards, harald
regards, Harald
