Drop down menu for lookup table
Sujan.Maharjan
Message 1 of 8
Sujan.Maharjan
Hi can i get drop down menu on lookup table for visibility states without having to create 2 lookups. Or any other way to do that maybe
Lookup
          Custom Text 2> Visibility state 1
                                > Visibility state 2
         Custom Text 2   >Visibility state 3
                                >Visibility state 4
"Revit Lies in the tension between what we want to do and what can be done!"
Replies (7)
Message 2 of 8
ojuris
Block properties table
Message 3 of 8
Sujan.Maharjan
I don't find any option for visibility state there. Could you post a screen shot jpg file or very simple block example
Message 4 of 8
Sujan.Maharjan
I almost Accepted your answer as solution. I'm attaching a dwg file here. I successfully created a simple one. But I do not find Visibility State option on the block I wanted to work with
Message 5 of 8
MetalFingerz
Message 6 of 8
Sujan.Maharjan
As i was exploring dynamic block discussion forum I came to know about about BTable. I found option to add all other parameters except Visibility state for block i created earlier.. I have attached my problem block in previous reply to @ojuris
Message 7 of 8
Libbya
You need to check the little box that forces the block to match a row of the table.  You will need to make sure the as drawn state of the block does match a row for it to work.
Message 8 of 8
ojuris
you can add visibility states in Lookup actions or in Block properties table but not in both
