WHY THIS MESSEGE (Cannot add distance constraint)
S_S_SS
Message 1 of 12
S_S_SS
Hello every one ….
I make a dynamic block and when i make a distance constraint Parameter AutoCAD give me this message in command bar
can some one explain this please ??
i uploaded the dwg
AND Thanks in advance ....
Accepted solutions (3)
Replies (11)
Message 2 of 12
h_s_walker
I don't have full AutoCAD so cannot fully help you.
HOWEVER, is your version of AutoCAD up to date with the latest patches?
Also try exploding those two blocks and then adding your constraint. It might be a case of AutoCAD not being able to add constraints to blocks.
Howard Walker
Left Handed and Proud
Message 3 of 12
S_S_SS
Thanks sir for interest
I made them as blocks to avoid using more and more constrains
i tried to make blocks and try constrains to them and i found that AutoCAD can make constrains correctly with blocks , but that specific block gave me error
i use AutoCAD 2021
Message 4 of 12
j.palmeL29YX
The elements of your block definition reside at different Z-levels.
Parametric works only with 2D geometric objects and all in the same plane.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Jürgen Palme
Message 5 of 12
h_s_walker
That means they will only work if the Z is the same level for the geometry. So if one Z=0 and one Z=45 it won't work
Howard Walker
Message 6 of 12
j.palmeL29YX
In >>this video<< I demonstrate with a simple example, that parametric constraints/dimensions will fail if any 3D geometry is involved. (And of course also not in a block definition).
This is one of the regrettable limitations of AutoCAD's parametric tool.
If my reply answers your question, click the "accept as solution" button. This can help others find solutions faster
Jürgen Palme
Message 7 of 12
S_S_SS
Thanks sir ...
how can i make all the drawing in one Z Axis easily ???
Message 8 of 12
j.palmeL29YX
One possibility:
Open (Go into) the block definitions (bedit or refedit command)  and move the "wrong" placed geometry to Z=0 as shown in >>this example<<
Jürgen Palme
Message 9 of 12
S_S_SS
Thanks sir ...
Message 10 of 12
S_S_SS
thanks sir ..
now I work on a 3d dynamic block
it must be in the same plane only ? or it must be in (xy) plan ?
or it mean that can i work on (xz) or (yz) plane ??
Message 11 of 12
S_S_SS
thanks sir ..
thanks
Message 12 of 12
j.palmeL29YX
Some simple tests as >>this<< should answer your question: Parametric dimensions and constrains work (with very few exceptions) only in the XY-Plane.
Jürgen Palme
