Attribute text move randomly in dynamic block
agrimmRU4TK
agrimmRU4TK
hello everyone i have an odd one not sure if this my software or how i made the dynamic block the stretches' and the rotation and the viabilities work but sometimes after stretching and then rotation the attribute text will not follow or will be off its base or insertion point. maybe someone could follow me what i mean live? not sure the best way to have it checked?
thanks...
here some screen shots and the dwg file attached below for review.
agrimmRU4TK_0-1637769928022.png here the issue
and here what it looks like in the block editor below
Libbya
The issue is caused by the fact that you stretch the attributes and not the point/moves.  Because of this, when stretching the attributes become offset from the point/moves.  This is not immediately obvious but becomes obvious when rotating, which acts on the point/moves and not the attributes.  If you want the issue to be even more obvious, then turn on a grip for each of the point parameters and then perform a stretch and rotate.  Anyway, there is a simple solution, remove the attributes from the stretch action and add the point/moves to the stretch instead.  See screencast:
See screencast.
h_s_walker
Your problem is you've added all the attributes to your line length stretch action. Remove them from it and add the WireTag actions instead
Howard Walker
Left Handed and Proud
agrimmRU4TK
thank you for the input it worked out as shown/described... i appreciate the help on this
