Weird problem with Dynamic Block grips.
mloszakiewiczYCWJX
Observer Observer
mloszakiewiczYCWJX
Observer
Observer
Hi there. I have a problem with dynamic blocks. The existing blocks inserted into drawings work fine, display grips and so on. When I create a new dynamic block, it does not display dynamic grips at all. Also, if I add parameters or actions to the existing blocks, the added functions do not appear in the block while the existing functions are not affected.
h_s_walker
Post an affected block
Howard Walker
Left Handed and Proud
mloszakiewiczYCWJX
Observer
Observer
Thanks for reply. For comparison: EstStairs300.dwg is unaffected, EstStairs300-1.dwg has an additional parameter and action that is affected, Random Block.dwg does not work at all (doesn't show any Dynamic Block grips).
h_s_walker
@mloszakiewiczYCWJX See the image below. The text is the same for your Random block as well, both distance parameters have the same exclamation mark. The problem is you have used the basepoint of the distance parameter as your start for the stretch. Delete the stretch action and this time use the actual point that you're going to stretch.
Howard Walker
mloszakiewiczYCWJX
Observer
Observer
It worked. Thanks.
