- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
There should be a very simple solution to my problem. All I'd like to do is the following:
- create a block which has a set of attributes.
- have these attributes free to move/relocate once the block is inserted into my drawing.
- have a leader connecting the set of move-able attributes to the block object.
- this leader should move with the set of attributes as I relocate the attributes after insertion so the arrow is always pointing at the block object and the landing is always attached near the set of attributes.
I've attached a dwg of my manhole block. I'd like it to work in a way that when I insert the block, it prompts me to fill in the attributes, then once I select an insertion point, I can move the attribute text around and still have the leader connected to them.
Thank you in advanced.
