Customize a Multileader as dynamic block
Millwood-k
Millwood-k
Is there any possibility to manage a multileader like a dynamic block, which allows you to set:
-angle type in a list instead of 360° free rotation
-distance type in a list not free stretch.
Any suggest will be Appreciated
h_s_walker
You can actually manually type in angle and distance and it will place the leader at the correct location
eg
Start your leader and then type 2<36 and hit return. 2 is the length of the leader and <36 is the angle.
Howard Walker
Left Handed and Proud
Millwood-k
Thanks hwalker showing this option, but actually I am using isometric drafting for piping project, I am frequently using this type of multileader with a block content, so this option looks not sufficient in case or I am not master it yet, because each time I need draw and move the multileader after choosing angle and length.
I have attached a snapchat which I use a manual palette.
Millwood-k
You said hit return, is that mean undo or something else? and do we type the inputs before or after clicking on in the model space?
h_s_walker
Return is just another name for the Enter button
Howard Walker
