Visibility 2 belong Visibility 1 into Dynamic block, CAN or CAN'T?
Message 1 of 8
Hi Everyone.
i've created Dynamic Block have use Visibility are table and chair, then i want to create many table type into visibility table, chair is same with table.
but i dont know how to creat it. so anybody can advise me about it?IMG_0594.JPG
Thanks!!
BR//
Binh Vo
Replies (7)
Message 3 of 8
Hi Libbya.
So we will use LOOKUP for TABLE or CHAIR type 1 2 3, rite?
if i want table type 2 = type1 + type 1
                      type 3= type 2 + type 1....
can we do it ?
if can, can u advise me this part?
Thank you.
Message 4 of 8
Hi Libbya.
i've watched your video, but i really dont understand all, cuz i'm amateur DB.
pls see my drawing. i've created dynamic block have use visibility TABLE and CHAIR.
so now, i want visibility TABLE have many TABLE 1, 2, 3, 4,....
eg:  when click to TABLE i can choose TABLE 1 or 2 or 3. while TABLE 2 have 2 tables, table 3 have 3 tables same like pictures bellow
note : TABLE 1, 2, 3 belong visibility TABLE in BLOCK
Can u teach me this part?
Thanks.
BR//
Binh Vo
Message 5 of 8
Libbya
The video I linked shows EXACTLY how to do that.  Pretend the Normally Open and Normally Closed options are Table and Chair.  And the valve type option is the number of tables or chairs.
Make a block that has ALL of the possible visibility states you want to be able to select.  In other words... table 1, table 2, table 3, chair 1, chair 2, and chair 3.  Make the appearance of the visibility states in whatever way you want them to appear.  Then add a gripless point parameter at the 1,1 coordinate point.  That point parameter is used as 'memory' to store the state of the individual selection lookups.  Add one selection lookup for table/chair and have it move the X position of the point parameter.  Add a second lookup for the number (1,2, or 3) and have it move the Y position of the point parameter.  Then add a double lookup and on one table add the point parameter x/Y positions as input for the six potential positions.  Change the visibility on the second table.
Message 6 of 8
good morning Libbya.
i've done some step as CAD file attachment.
supposed : PORT DUAL is TABLE while SINGLE PORT CHAIR.
i've put lookup 1 is dual and single. but it isn't change symbol.
can u help me???
Message 7 of 8
Libbya
Is this what you are looking for?
Message 8 of 8
Yes!!!!!!!! Libbya
That's what i want to do.
u are expert about DB.
Thank you so much!!
BR//
Binh Vo
