Having problems trying to find best way to keep text in the correct position when using linear stretch pair.
It works perfectly when text (justified center) is on the left & linear stretch is used. However when I flip text to right side & then use linear stretch that's when the block breaks down.
I've attached an example block, I'm probably just missing something simple but I'm not sure what.
Any help would be much appreciated.
Solved by j.palmeL29YX. Go to Solution.
When you say "breaks down", it would be better if you could describe what you want it to do and what's wrong with it.
@ed57gmc wrote:
... describe what you want it to do and what's wrong with it.
The problem seems to be clear for me: dragging the length of the line the not flipped Attribute moves as if it were "connected" to the left end of the line. If the attribute is flipped, it moves in the wrong direction - it should move in the opposite direction (as if it were "connected" to the right end of the line).
Jürgen Palme
A first attempt attached.
Is that what you're looking for?
Jürgen Palme
Thanks Jürgen, yes, you can figure it out. But I didn't want to assume that was exactly what they wanted and I have a lot of work to do and it's helpful if I can spend less time troubleshooting. It's nice when they explain that the first time. Hence, my request.
