Message 1 of 11
09:05 AM
- Mute
- Permalink
- Report
Hello everyone, I'm still in school for drafting but managed to land a job doing mechanical drafting. I'm making a block for a condensate pot template, and I'm supposed to use Point Parameters and a Lookup Table in such a way that the Point Parameters locations are given in the properties palette. The idea is that once the template block is inserted and the proper pot configuration and size put in with the Block Table (already done), the Point Parameter locations can be used to insert the connections to the pot (they will be separate blocks). I've looked for a solution for days and can't figure it out, and it seems like nobody else on the planet has ever had this problem before.
