Scale Dynamic Block from Center/Base Point
I'm trying to scale a dynamic block from the center/base point of the block using a Block Table and keep the base point in the center. I've tried a couple different things such as adding a move Action with a .5 distance multiplier but I don't think I did that correctly.
I have attached the block as I currently have it.
Any input would be greatly appreciated - Thank you!
Libbya
No need for any move actions.  Just select the scale action, go to properties, set Base Type to independent, and move the new grip to the center.  See screencast.
Libbya
Fantastic! Thank you so much! 👍
sukrusirtikara
Observer
Observer
I can't see the screencast
Libbya
I don't understand what you are trying to say.
