Update Dimensions via Excel cells
Hello
Is it possible to set a block's dimensions to read an excel table's cell value and update the dimensions (i.e. change the size of the rectangle) based on values entered in an Excel table?
For example, given a rectangle that has dimensions X (Width) by Y (Height) and a table that has the X and Y values given in cells A1 and B1 linked from an excel spreadsheet.
Libbya
With only stock AutoCAD?  Nope.
What version of AutoCAD would I need to accomplish this?
Libbya
There is not any version of AutoCAD that will accomplish this.  You would need to use custom code.
Okay, thanks for your help! Will look online for a how to on this.
