- Mute
- Permalink
- Report
How do you get rid of a “custom” line in a lookup table? It makes sense that it will appear if the actual geometry does not match any row in the table, but in this block I have not been able to figure out why it should not match.
The attached dwg contains a block that will be part of a title block. The geometry is a representation of a site plan (in random scale) on which you can apply hatch to buildings or part of buildings to indicate the location of the current drawing. Rather than using visibility, the hatch can be turned off by scaling it down to a practically invisible dot. It is actually working as it should, but the "Custom" line in the Lookup will be confusing for the users.
Thanks in advance for any help
/Ebbe
