Message 1 of 13
12:53 PM
Is it possible to use a DB with viewports? The attached file contains the DB with notes indicating what I would like to do with the DB. Basiclly I made a stretchable box that would be used on our detail sheets. This box has text that will stay at its location in relation to the DB. I've noticed that I can not use constraints on the DB after its inserted into the drawing. Is this normal? For example, I want to add a viewport to the DB and constrain its size using parametric dims but when I do this the DB is no longer a DB. Hopefully the attached file can better explain what I need. Perhaps I'm asking too much.
Spoiler
