Multiple Visibility
Multiple Visibility
Multiple Visibility
Hi,  could really use a some help with streamling this block,  visibility look up for multiple parameter/actions ...  would like to be able to turn on or off each one independently versus combination of visibility states.
While im at it .  looking to stretch the Hinges equally, top hinge is always fixed, and equally spaced between, would like to enter value for dimension to equal c.c. (value input) not incremental .. 28 5/8" as default and then enter new equal dimension i.e. 30 1/4"
Looking forward to refreshing my ancient autocad skills , is it the same as ridng a bike ?
Cheers
Richie Rich
I would think it needs lookup tables. The possibilities are endless
Libbya
If you search the forum you'll find that I've posted other screencasts on how to add multiple visibility selections.  Here's one specific to your block.  The single selection lookups move the individual point parameter X values.  The double lookup uses those X values on one table to determine the row and on the other table changes the visibility state based to the appropriate row.
