Twisting Block
Twisting Block
CodeDing
Advisor Advisor
Twisting Block
CodeDing
Hello All!,
I'm fairly new to building dynamic blocks and I can't seem to resolve this issue, so I;ve come to the community. Hopefully someone can get me on the right track...
- I have a dynamic block with 2 visibility states (use the larger visibility, my issue is more evident)
- When I reduce the diameter with the grips, my surrounding items twist  which I DO NOT want to happen.
Overall Goal: have brackets adjust with diameter while maintaining their assigned angle.
I have attached the block for you to play with.
Best,
~DD
Block starts out normal
After reducing diameter, brackets have twisted
Libbya
Don't mix and match constraints and dynamic parameters/actions unless absolutely necessary, and expect bad behavior if you do.  One exception is the use of visibility states, which will not conflict with the constraints.  In this case, if you want to use constraints, get rid of the rotate parameter and do your rotation/angles using angular dimensional constraints and construction lines if necessary.  If you want to use the rotate parameter/action, then get rid of ALL of the constraints.
In this case, it's probably easiest to get rid of the rotate and use an angular constraint.
CodeDing
@Libbya,
That worked perfectly. Thank you for the guidance.
Best,
~DD
