I've been struggling to make a dynamic cabinet door array that does exactly what I'd like it to do and have tried some of the techniques posted in the forum to no avail. I'd like to set up a dynamic block that has left and right swing hardware along with the cabinet door, that automatically centers itself on the cabinet face that I'm dragging along. Once I have that figured out I'd plan for 12", 15", 18" door widths. Attaching a CAD file of the thought process. Any guidance here would be appreciated!
Solved by j.palmeL29YX. Go to Solution.
Would you please post an example how the result should look after dragging the grip? After reading your text several times I still have problem to understand your goal 😞
Jürgen Palme
The CAD file really is showing the result of dragging the grip, my intention would be to start with 2 cabinet doors, and as you drag you end up with a full run.
Without exactly knowing what you want to achieve, here a first attempt.
Jürgen Palme
Notwithstanding your (I suspect) drawing mistake(s)
attached my result (suggestion) of another interpretation of what you perhaps want to achieve.
Jürgen Palme
Are neither of the two suggestions (Post #4 or #5) an acceptable solution to your problem? If you need further help let us know what youe're missing.
Jürgen Palme
Thank you Jurgen, that is exactly what I was trying to accomplish.
Cheers
