Dynamic Blocks Forum
Troublle with the array-function in dynamick blocks
2 REPLIES 2
399 Views, 2 Replies
I have created some simple dynamick Blocks off a staircases, but have some trouble with the Array action, see the attached file.
When i strech one of the stringers, i also want to array the steps (red line), but the step-lines just dissapere...?
If i reset the block, the step-lines comes back....
Anybody who can help a novice (in dynamick blocks)..?
John
John
2 REPLIES 2
jarredmonday
jarredmonday
it seems like (at least over here) that the actual dynamic block does not have you redlines. Which may be why your Array1 doesn't have anything attached to it.
I would go into the block editor and click on the "save block as" check the box "save block definition to drawing file". Open that up and start from there and do a little house keeping.
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
in reply to: jarredmonday
Thank you for your responce.
I cant tell what the problem was, but i have solved it now. The dynamick block was created in a acadLT-version. In the full acad-version there was no problems...!
AutoCAD Inside the Factory
