Dynamic Blocks Forum
Trouble with dynamic block basepoint.
2 REPLIES 2
NickyYBRXE
237 Views, 2 Replies
I have a cross section that rotate and stretches via polar stretch and keeps the attributes horizontal.
This works like a charm. but now I want to add a basepoint in the middle that stays in the middle after it stretches en rotates.
I know that i have to use a distance multiplier of 0.5 but when I apply the stretch the attributes go crazy.
So hopefully someone can help me fix it.
2 REPLIES 2
MMcCall402
in reply to: NickyYBRXE
You need to move it the same way the ends are moved, indirectly with a Point/Move linked action and two polar stretches at 0.5 distance multipliers.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
NickyYBRXE
in reply to: MMcCall402
Thanks, simple solution that i never thought of.
AutoCAD Inside the Factory
