Help with Lookup or multiple Visibility
kzD1219
Message 1 of 25
kzD1219
Hi I have been looking at other posts, but missing something.  There are a few things going on with this block.  Definitely a novice when it comes to dynamic blocks.  Never used lookup since I never understood them.  Seems pretty straight forward after watching a video, but can't seem to get this one to work.
There is a Scale Bar that has multiple scales so I used Visibility to get that.
There is a distance so we can stretch the Scale bar to fit our different size sheets.  However a Lookup would be more beneficial, but I can't seem to get it to work.
There is a north arrow that I can rotate, but looking to toggle the north arrow on and off (since we may or may not use it depending on the situation).
The dwg is attached.
These are the values I am looking for to do the stretch
This is the north arrow to be toggled on or off.
Would love some input and appreciate any help.
Replies (24)
Message 2 of 25
Libbya
The block you attached does not appear to have any lookups.
Message 3 of 25
kzD1219
No it doesn't. I didn't get it working so I got rid of it for now. But took a screen shot of the distances on the lookup for reference. I have tried it multiple times since this posted, but still not getting the stretch distances to work.
Message 4 of 25
Libbya
Post a version WITH the lookup added and filled out as you show.  That way someone can test the block and see where you have gone wrong.
Message 5 of 25
Libbya
Actually, I can see what you did wrong in the file you posted.
You created your linear parameter backwards.   The big yellow warning exclamation point at the action end is the big clue.  When creating a linear parameter, the first point you select is the base point, the second selected point is the end point.  When a lookup changes the length of a linear parameter, the base point remains stationary and the end point is moved to adjust the length.  Your block has the parameter backwards so the base point has the action associated with it.  Because of this, when the lookup changes the linear parameter length, the end point (which does not have any actions associated with it) moves but nothing appears to happen.
To fix it, deleted the Distance1 parameter.  Make a new linear parameter and pay attention to which end you pick first.  Then associate the stretches with the linear parameter.
FWIW, using visibility states to change the scale text is very inefficient.  Instead, use an attribute for the text and use a block properties table to write the values directly to the attribute.  This gives the benefit of allowing custom text if desired and still maintaining all of the selection text options for the scales.  It also has the benefit of freeing up the visibility states for turning the North arrow ON/OFF.
Message 6 of 25
kzD1219
Sorry for the delay, work and life got busy, I will definitely look into this and post an updated block when I can and fix up that distance.  I saw that yellow exclamation too, but wasn't sure how to fix it.  Again only really scratched the surface with this.  Never created a workable lookup, but know it is something I need to learn and will make this work better because of the multiple different lengths we can stretch the scale bar line to.
Message 7 of 25
kzD1219
Looking at this again.  I see the exclamation point you are talking about, but no matter which way I make the stretch, it stays there.  I also added the lookup table so that is working now thankfully.  I don't quite understand using an attribute for the text and a block properties table.  Sounds cool, but I haven't done that ever.  The scale ticks are in different positions depending on the scale so how is that handled with an attribute.  Would love to still turn the North Arrow off and on, that is about the only issue that is still ongoing.  Open to suggestions, but again, a little over my head here too.
Message 8 of 25
j.palmeL29YX
@kzD1219 wrote:
I see the exclamation point ..., but no matter which way I make the stretch, it stays there.
Set the Number of Grips to 1.
Jürgen Palme
Message 9 of 25
kzD1219
Thanks, that was a simple fix.
Message 10 of 25
j.palmeL29YX
I'd suggest to create two different blocks - one including the North Arrow and an other without them.
Jürgen Palme
Message 11 of 25
j.palmeL29YX
Attached an attempt using a Block Properties Table.
(I didn't yet check in depth if the values in the table all are correct. You should still check that).
Jürgen Palme
Message 12 of 25
Libbya
In that situation, I wouldn't make two different blocks.  Currently the visibility states are used for two purposes; scaling the positions of the scale marks, and showing different text values at the scale bar and the scale.  Both of those purposes could easily be accomplished with a single visibility state and the use of a block properties table to simultaneously change the position of the scale marks/text and simultaneously writing the values to the text.  That would leave the visibility parameter free to turn the north arrow on/off.
Message 13 of 25
j.palmeL29YX
Oops, the upload above didn't work properly. 😞
I hope now it's ok.
Jürgen Palme
Message 14 of 25
j.palmeL29YX
Full agree. It was only a crutch because @kzD1219 wrote he is not (yet) familiar with using block tables. In the meantime I posted a (hopefully) better workíng example (without further explanation).
Jürgen Palme
Message 15 of 25
j.palmeL29YX
Here an improved version, including some small bug fixes.
Jürgen Palme
Message 16 of 25
kzD1219
I appreciate the help.  This works exactly like I was hoping for.
Message 17 of 25
kzD1219
Quick question if you are able to answer.  The scales should show up below the title so what I did to add the scale was make another attribute, and add it to the block properties table.  That seemed to allow the scales to show up below the Title.  I think that will work, correct?
But if I do need to move a tick at the other end for a particular scale, how would I go about that. Just in case I didn't get the right scales and need to fix that up.
Message 18 of 25
j.palmeL29YX
I deleted all your MTexts, but added an Attribute whos default is a Field -> Blockplaceholder -> Scale_ .
To update the view you must "Regen" the file.
[EDIT:] I'm not sure whether the current design meets your expectations. - maybe in the "Arrow OFF" VisState you should enable the Visibility of the Lookup1 grip. (perhaps you forgot it ?)
Jürgen Palme
Message 19 of 25
j.palmeL29YX
I don't understand your question. Would you please show us an example what you want to do or to achieve.
Jürgen Palme
Message 20 of 25
kzD1219
@j.palmeL29YX
Hi not sure if you remember this.  You helped me out tremendously with a block for a metric scale bar. My manager came back and loves it so much he wants an imperial one.  Which I believe I have set up and it works ok.  But if I compare the metric one you set up to the imperial one I am missing the Linear parameters with the move action that I see on the metric one.
If you have a minute, could you please look at the imperial dynamic block and let me know if I actually need those move actions?  Not quite sure what they do and probably the simplest thing to set up. When setting it up, the 'tick marks' don't move correctly (the actions are currently not in the drawing).  I am attaching the metric block which we have been using and love and the 'Imperial template.dwg' which I would love your opinion on.  First time setting up visibility and Block properties table.
