FIXED! SEE SOLUTION IN COMMENTS BELOW. THANK YOU!
I'm hoping this is a stupid easy fix. I'm not very skilled with dynamic blocks and none of the online tutorials or autocad videos have helped.
Here is what I need my block to do.
36" PV panel side view with linear array to add another module next to it with a 1 inch space. (array set to 37" to allow 1 inch spacing between modules)
Dimension that will stretch to include each panel added. (stretch set to 37" dist increments)
- Example:
- If there is one module, the dim will read 3'-0".
- If there are 2 modules, the dim would read 6'-1".
- If there are 3 modules, the dim would read 9'-2"
- and so on...
- Example:
The problem:
(see screencaps) (BLOCK POSTED BELOW) (screenshot of desired outcome also posted below)
I can create the dimension stretch that increases by 37" just fine.
I can create the module array that adds a new module with 1" spacing just fine.
As soon as I try to put both actions on the same parameter, the first action stops working. Right now, I created the dimension stretch first, added the array, and now the dimension doesn't stretch while the array works fine.
The only thing that I can think of that would screw it up is the fact that the parameter (DISTANCE 1) is 37" and starts 1" to the right of the 36" module to keep the 1" gap between modules. The dimension I need to stretch is 36" like the module. I wouldn't think that should be a problem since I'm only grabing one side of the dims, but here we are.
If anyone has any thoughts I would be grateful for the assist. Check out the screencaps to see if you notice any errors in my process.
Thank you!
