trapezoid with frame using parametric constraints
Thank you all for your participation in this forum. I've been able to learn a lot about dynamic blocks, and I've searched a lot but have not found an answer to this dynamic block problem I am trying to solve.
I have created a trapezoid shape that has adjustable heights on both sides, as well as an adjustable width. In addition, I want this trapezoid to have a frame of a specified distance that can be adjustable as well.
I was unable to achieve this using the traditional parameters and action sets, so I attempted to create this by using the parametric constraints.
Although I've created this shape that does what I want it to do, the block tells me that it is unconstrained. However, every time I attempt to constrain some aspect of it, it interferes with the way I want the block to function.
My question is twofold:
1) Do you have any suggestions as to how I can fully constrain my block, while allowing it to perform as it currently does?
2) Do you know how to create this block using the conventional parameter and action sets? I could not for the life of me figure out how to get the frame to behave properly with the changing angles.
I'm using AutoCad 2014.
Thank you very much.
ojuris
hi!
See attached drawing.
I use mline and have 1 problem with it. You can't direct change distance between lines but you can change that distance to predefined values (trough double lookup). I don't know is it ok for you.
