Hello all,
I am trying to make a Dynamic block for Circular Hollow Sections. So i have a block properties table with 3 columns.
SIze (description) | Outer Diameter | Thickness
i can add a diameter constraint to the OD no problem but how can i add a thickness constraint? i cant pick say a linear or horiz between the quadrants of each circle it does not let you.
Now clearly i could convert all my tabular data to Inner Diameter instead of Thickness but i was looking to see if there is a way i can do it like described?
Also - i think i could also do this with an equation in Parameters Manager but for some reason that does not open, every time i click it the dialog does not display nor does it show anything at command line, i know this means its maybe corrupt but i can afford the time to reinstal just now.
Any and ALL help is much appreicated.
Can you post your block so far?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
I'm assuming that 'T' is a 'String Paramater' you've created?
If so, add a Radius to you're inner circle that '=D-T', then hide the 'radius paramater' so it doesn't appear in properties.
Sorry, Mathematical error, the inside should be a radius, therefore the expression should be 'D/2-T'. That will allow your Thickness and Outside Diameter to display correctly.
