Text over lines
Text over lines
tjo9185
Message 1 of 9
Text over lines
tjo9185
So I’m trying to make this magic happen that my boss is convinced worked before, but i guess his system crashed and he lost this stuff.
So what I want is text such as UE (underground electric), to be picked from my tool palette and when I place it on a line it will break the line around it so I looks like this
—— UE ——
Not only should it break the line but it should also be annotative in that no matter what scale I bring it into it’s just the right size text without having to rescale anything.
now ive tried to do this with a block that contains a wipeout. The block is originally on an 1/8” scale drawing and when place on 1/8” it works well. But it needs rescaled if I were to put it on a 1” = 60’ which is a scale these blocks go into often. I made the blocks annotative but that doesn’t seem to be working correctly because the block comes into a drawing being sometimes 20x too big.
but when I made a block from scratch that only contains a text and mark it as annotative it seems to scale properly to any size drawing I have listed. But then it doesn’t have the wipeout so it doesn’t mask or break the lines.
I am at a complete loss and I’m under a bit of pressure to make this work, any help would be appreciated
-apparently a magician
Replies (8)
Message 2 of 9
j.palmeL29YX
Try the attached example.
Jürgen Palme
Message 3 of 9
clindner
@tjo9185,
Have you considered using (making) a complex linetype to accomplish this? They really aren't that hard to create, and if the text is based on an annotative style, you're all set.
Please use the Accept as Solution or Kudo buttons when appropriate
Chris Lindner
CAD Technology Consultant @ onebuttoncad.com
AUGI Board of Directors
Message 4 of 9
clindner
Love it, @j.palmeL29YX
Made one tweak (attached) that will simplify things a lot - added an alignment parameter!
Chris Lindner
Message 5 of 9
tjo9185
Amazing thank you! I was actually able to get it close to correct on my own but this really takes the cake. The alignment parameter is next level
Message 6 of 9
j.palmeL29YX
@clindner wrote:
... added an alignment parameter!
Well, a lot of "fine tuning" is still possible. I mainly wanted to show an example which hides the objects behind and is scaled automatically to the current scale factor. Whether @tjo9185 wants always aligned text or always horizontal text - I (we?) don't yet know that 😉
Jürgen Palme
Message 7 of 9
clindner
My adding to your solution should not be interpreted as a critique. Nor was I implying that you forgot to add something. Like you, I also wanted to show an example of what was possible based on my interpretation of his needs.
Chris Lindner
Message 8 of 9
clindner
Cool! You're very welcome, @tjo9185
Chris Lindner
Message 9 of 9
j.palmeL29YX
Don't worry, I didn't take it as such either.
Have a nice day.
Jürgen Palme
