Dynamic block.
There are several point options that move my attributes depending on the selection option.
The bases of these parameters and the attributes themselves are clearly located, and their coordinates are correctly entered in the selection table,
which actually confirms by the testing unit.
Now I just insert my block into the drawing - it corresponds to the default state of the block.
However, the selection parameter shows that I have a custom selection (does not match the selection table).
If I change my choice - I will have all the attributes whose point parameters participate in the selection table,
are shifted to the right by a certain distance. The phenomenon does not lend itself to my logic. Is this a bug in AutoCAD? I have AutoCAD 2019.
P.S. the selection parameter shows that I have a custom selection (does not match the selection table)
even in test mode, however everything is displayed there correctly.
