Dynamic block with attribute text 2
jamesmac1201
jamesmac1201
Attached is a simple section arrow dynamic block. The attribute text doesn't display. It does display in the block editor (and even the "test block" option). Any suggestion?
Libbya
Any time you make changes to attributes that are within blocks, you need to run the ATTSYNC command in model space for those changes to take effect in existing insertions of the block.
Libbya
I would mention also mention that dynamic actions will not work on any attributes that do not have their property locked = yes.  If you want them movable you can add a point/move after they are locked.  This particular block does not have any dynamic actions acting on the attributes but it is a good habit to always lock them.
jamesmac1201
Perfect. Never knew of that command. That was driving me crazy. Also, per your other post, I updated the attributes to include the "Lock Position". Thanks again.
