Sync blocks across drawings
seanNKRS3
seanNKRS3
Good morning,
Just wondering if anybody can lend a hand. I'm sure this is a simple.
I have 2 drawings which both use the same dynamic block. On drawing A I have amended/improved teh design of the block. I was hoping somehow to carry this across to drawing B.
If I cut and paste the original design remains.
Thanks for you help!
vinodkl
Use "RENAME" command in drawing A and rename the dynamic block into different name and then copy the dynamic block from drawing A to drawing B
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
ojuris
In drawing B open Design center (Ctrl + 2). In Design center find drawing A, in Blocks find your block, right click and Redefine only.
