Frammentazione in pixel.
frugiuele.cesare.natta
Ultimamente la videata Cad, improvvisamente, si frammenta in pixel. Rigenerando il disegno, torna normale. Qual'è la causa? Adopero da anni il software per uso didattico e non è mai successo.
Grazie.
vinodkl
Ciao,
Leggi questo:https://forums.autodesk.com/t5/autocad-forum/screen-glitches-seen-recently/m-p/9410088#M1015093
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Mi spiace ma non ha funzionato.
Grazie comunque.
Ci sarà un'altra soluzione?
I'm sorry but it didn't work.
Thanks anyway.
Will there be another solution?
vinodkl
Check if your graphics is certified to be used with AutoCAD from this link: Certified Graphics Hardware
If in case you have updated the graphics driver after which you are facing this problem, then roll the back the drivers.
Also check this thread: https://forums.autodesk.com/t5/autocad-forum/pixel-graphic/td-p/9436012
Mi dispiacerebbe annullare gli ultimi aggiornamenti della scheda grafica...
Eventualmente, comunque, si potrebbe fare? Come?
Non c'è una soluzione alternativa?
Grazie.
I would be sorry to cancel the latest updates of the graphics card ...
Eventually, however, could it be done? How? There is no alternative
solution?
Thanks.
vinodkl
Sorry there is no alternate solution. This is actually a problem from the updated drivers and many are facing this issue. There is no problem with AutoCAD. So you need to wait until they find out and fix it.
You could try turning off "_3DCONFIG" and see if the problem gets eliminated.
