Switch From Imperial To Metric
christianbaileypaulsen1
Message 1 of 12
I have a block that diplays x and y coordinates. I want to be able to switch it from imperial to metric either via a lookup table or visibility state, or anything really. Please let me know if you have any ideas. Thank you.
Replies (11)
Message 2 of 12
MMcCall402
I think I would opt for a second set of attributes for the X an Y coordinates formatted for the metric values and two visibility states to choose which ones to display.   The other attributes can be visible in both states.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
Message 3 of 12
Yes thats what i wanted to do with the visibility state. The only problem is that i cant find out how to get it to show up metric. That option doesn't show up when i insert a field.
Message 4 of 12
MMcCall402
If you're looking to display a metric equivalent value in an cad file with imperial units you would need to apply a conversion factor to get to a metric equivalent.
1 foot = 0.3048006096012 meter
If you're looking to use this block in both imperial and metric unit cad files ... I'd make one block for each as the scaling/sizing might be too different.
Mark Mccall
CAD Mangler
Message 5 of 12
The conversion factor box is greyed out and set at 1 whenever i try to click additional formatting and edit it.
Message 6 of 12
MMcCall402
Rather than using the BlockPlaceholder directly, choose Formula, then in the formula area right-click and choose field, then choose BlockPlaceholder for the value. This will put the field value into the formula area where you can now enter in the conversion factor.
The process kind of puts a field within a field.  You can put more fields into formulas to make calculations using values derived from several filed sources.
Mark Mccall
CAD Mangler
Message 7 of 12
What would the forumla look like? InsertionPoint*25.4? That gives me 3 coordinates separated by commas?
Message 8 of 12
MMcCall402
That depends on the units you're converting from, and to.  Feet to meters?  Inches to centimeters?
Be sure to carry the conversion value to enough decimal places to fit the level of accuracy you need.
Mark Mccall
CAD Mangler
Message 9 of 12
Feet and inches to centimeters.
Message 10 of 12
MMcCall402
1 foot = 30.xxx-xxxxxxxx centimeters
Mark Mccall
CAD Mangler
Message 11 of 12
1 inch = 2.54 cm. I dont know how to put that in a block.
Message 12 of 12
MMcCall402
The UNITS setting in the cad file you posted was in Feet.  1 drawing Unit = 1 foot.
In the BlockPlaceholder for the X and Y field be sure to select the format to be Decimal.  This will retrieve the value as feet and decimal portion of a foot. You don't need to convert inches, just feet in the decimal format to centimeters.
Mark Mccall
CAD Mangler
