Switch From Imperial To Metric
christianbaileypaulsen1
I have a block that displays the X and Y coordinates of itself, and also populates a data extraction with those X and Y coordinates. Id like to be able to switch it from imperial to metric using maybe a lookup table or a visibility state. Please let me know if you can think of a solution. Thank you so much.
h_s_walker
Here you go.
It's got 2 visibility states. Imperial and Metric
Howard Walker
Left Handed and Proud
That works fine but how did you do it? I see you used formula but im not really sure how it works. Could you explain what formula you used to get this?
Also for some reason your blocks metric attribute do not work in a data extraction. Any clue why?
And can we please do cm instead of mm? I cant figure out how to edit you formula. So if you could post the new block id really appreciate it.
h_s_walker
See the attached Screencast. I put in 25.4 because that's how many millimetres are in an inch. If your drawing was metric I would have put 10/254, which is the same as 1/25.4 (LT can't do fractional calculations)
Howard Walker
h_s_walker
Watch the screencast I've just posted and instead of putting 25.4 put 2.54
Howard Walker
