Stuck working on distributed load dynamic block
aththorsen
Observer Observer
aththorsen
Observer
Observer
 Hello, AKN!
I am relatively new to creating dynamic blocks and I've been working on this block for a long, time trying to make it how I want it. I'm a civil engineer and I want to create a dynamic block for distributed loads. I just can't get it right. I've attached a .pdf-file of a handdrawing explaining how I want it to be and I've also attached the block file. If anyone can fix it I'll pay $100 via PayPal. Any pieces of advise that can get me further in the proces will also be warmly welcomed!
Kind regards!
Andreas
Libbya
Is there are workable limit to the number of arrows?  In other words, is there any a time you would need more than 10?  More than 20?  More than 100?  What is the max you could realistically see needing?
aththorsen
Observer
Observer
By arrows do you mean red arrows visible in the block or the blue grip arrows? The red arrows would most likely not exceed 100. In case it does I guess I could just copy the block and let the start point be the end point of the first one. If 300 is not a problem then I can say for sure it will never exceed that amount 🙂
