Dynamic Blocks Forum
Stretch Wipeout
29 REPLIES 29
Message 1 of 30
2699 Views, 29 Replies
Stretch Wipeout
I consider folowing problem: is it possible to create dynamic block with strech action include wipeout object (frames are turned off). Any ideas?
Thanks, Chris
29 REPLIES 29
Message 21 of 30
jarredmonday
I am using Autocad 2013 and I could not adjust my wipeouts in any way. I found that if you Uninstall "Autodesk Sketchbook Designer FOR Autocad" you will be able to modify any and all you wipeouts.
Keep inmind there are two programs, "Autodesk SketchBook Designer FOR Autocad" & "Autodesk SketchBook Designer"
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Message 22 of 30
Bob_Zurunkle
in reply to: jarredmonday
That's what I said lol Smiley Very Happy
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted 🙂
Message 23 of 30
varad.keshatwar
I think it is not possible to create  dynamic wipeout in AutoCAD. I tried it with AutoCAD 2022. My block stretches but wipeout remains at the original position. I guess the wipeouts are static. Autodesk need to see to this, @Charles_Shade what do you think.
Message 24 of 30
hwalker
in reply to: varad.keshatwar
@varad.keshatwar you can stretch wipeouts. See the attached drawing. The inner rectangle is a wipeout
Howard Walker
Left Handed and Proud
Message 25 of 30
Charles_Shade
in reply to: hwalker
Agreed with my good mate Howard.
And they ARRAY well too.
Message 26 of 30
varad.keshatwar
@hwalker I agree your wipeout stretches, but it stretches manually. I'm interested in dynamically constraining the WipeOut which is I guess not possible currently with AutoCAD 2022.
By dynamically constraining I meant, by using Dimensional Constraints
Message 27 of 30
hwalker
Ah I only have LT2016 at work so cannot try stretching it with constraints
Howard Walker
Message 28 of 30
varad.keshatwar
Can you consult with any Autodesk Expert, regarding this issue
Message 29 of 30
hwalker
We are all users just like you. Expertise varies from person to person, that said
@j.palmeL29YX have you any idea how to make a wipeout automatically stretch using constraints?
Howard Walker
Message 30 of 30
j.palmeL29YX
Wipeouts don't have Constraint Points. So it's AFAIK not possible to assign  neither geometrical nor dimensional constraints.
A work around may be to use an assoziative SOLID hatch with color 255 and constrain its boundary.
Jürgen Palme
Forma Design Contest
AutoCAD Beta
