Dynamic Blocks Forum
STRETCH VISIBILITY NOW SHOWING AFTER CREATING ONE IN BLOCK EDITOR
3 REPLIES 3
carolinaERN7V
188 Views, 3 Replies
Hi there,
I've been having this issue for a couple of weeks when I create a new dynamic block with multiple actions in the block editor and then I save and try to work on it in the model, some of the action buttons are not showing, then I go back to my block editor to make sure that everything was set up and everything seems okay. it's been happening specifically with the stretch action not showing in the model.
I'm attaching pictures and CAD file showing the block in the block editor and how it looks in the model.
Labels (1)
3 REPLIES 3
Libbya
in reply to: carolinaERN7V
The images aren't helpful.  Post the file(s).
carolinaERN7V
in reply to: Libbya
Uploaded! thanks
Libbya
When you set a linear parameter to show a single grip that grip is always shown at the parameter's end point and not the parameter's base point.  You associated the stretch action with the linear parameter's base point (which does not have a grip).  The end point does not have any action associated with it so even though the grip exists in block editor, the grip is not shown in model space, because without an action associated with it there is no reason to show it.
Delete the linear parameter.  Add a new one.  Associate the orphaned stretch action with the new linear parameter, and pay attention to which end point you associate it with.
Autodesk Customer Advisory Groups
”Boost
